Zum Hauptinhalt wechseln
Astak Mole Motherboard Replacement
Was du brauchst
  1. Astak Mole Motherboard Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Remove the four bottom tabs in order to access the bottom screws.
  2. Astak Mole Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove all four 14 mm Phillips #1 screws.
  3. Astak Mole Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the SD card.
  4. Astak Mole Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Pry up the motherboard on the four points using a spudger.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Astak Mole Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Gently pull back the motherboard to expose many of the component's wired connections.
  6. Astak Mole Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 2 Astak Mole Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 2
    • Sever the indicated adhesive connections to the motherboard allowing the wired connections to be removed.
    • All wired connections to the motherboard are removed by the thin plastic male connector inserted into the larger female plastic connection.
  7. Astak Mole Motherboard Replacement: Schritt 7, Bild 1 von 2 Astak Mole Motherboard Replacement: Schritt 7, Bild 2 von 2
    • The red wires may be adhered to the CPU as indicated and will need to be severed as shown.
    • Be careful not to scratch the CPU in this step. This is not a wired connection.
    • Sever the additional adhesive connections so that the wired connections may be removed.
  8. Astak Mole Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Locate and unscrew the indicated screw using the (PH1) Phillips head bit.
    • Screw Measurements: (Length= 5.3mm)
  9. Astak Mole Motherboard Replacement: Schritt 9, Bild 1 von 2 Astak Mole Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Remove the last two wired connections to the motherboard by severing the indicated connections.
    • Lift up the secondary motherboard as indicated using the metal spudger.
    • All connections should be severed from the motherboard and a new motherboard may be inserted.
    • It is advised to reapply adhesive to wired connections during reassembly.
Abschluss
Andrew Birch
204 Reputation
2 Anleitungen geschrieben
USF Tampa, Team 2-2, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-2, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G2
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 16
Insgesamt: 497
