Zum Hauptinhalt wechseln
Astro A20 Microphone Replacement
Was du brauchst
  1. Astro A20  Microphone Replacement, Cushion: Schritt 1, Bild 1 von 1
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Astro A20  Microphone Replacement: Schritt 2, Bild 1 von 1
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Astro A20  Microphone Replacement: Schritt 3, Bild 1 von 2 Astro A20  Microphone Replacement: Schritt 3, Bild 2 von 2
    • Remove the ear cushion from the headset.
  4. Astro A20  Microphone Replacement, Microphone: Schritt 4, Bild 1 von 1
    • Place one hand on the back of the speaker.
  5. Astro A20  Microphone Replacement: Schritt 5, Bild 1 von 2 Astro A20  Microphone Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 7mm screws with a Phillips #1 screwdriver.
    • You may want to use a 60mm screwdriver extension to reach the screws inside of the headset.
  6. Astro A20  Microphone Replacement: Schritt 6, Bild 1 von 2 Astro A20  Microphone Replacement: Schritt 6, Bild 2 von 2
    • Lift the speaker area.
    • Disconnect the wires that connect the microphone.
    • Remove the 7mm screw with a Phillips #1 screwdriver.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Alabama, Team S1-G2, Bedsole Fall 2018 Mitglied von University of Alabama, Team S1-G2, Bedsole Fall 2018
UA-BEDSOLE-F18S1G2
4 Mitglieder
10 Anleitungen geschrieben
4 Kommentare
worked for me….thanks
Thompson Crusher - Antwort
listen my mic peace is messed up is there like a fix for that
Bruh Bruh - Antwort
were? are you getting the new mic from? please link the site
jrod6t9 - Antwort
this really worked! There was no need to get a replacement mic since it was just a torn cable not making good contact. Thanks a lot!
Lineth Jauregui - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 31
Letzte 30 Tage: 145
Insgesamt: 11,876
