Zum Hauptinhalt wechseln
Einleitung
If you need to replace an damaged or uncomfortable ear cushion for the Astro A20, you will need a spudger and a new ear cushion.
Werkzeuge
Ersatzteile
  1. Place one hand on the hard side of the headset ear portion and on the cushion.
    • Place one hand on the hard side of the headset ear portion and on the cushion.
    • Lift the small portion on the edge of the cushion.
  2. Slide the metal spudger underneath the lift part of the ear cushion.
    • Slide the metal spudger underneath the lift part of the ear cushion.
    • Pull the ear cushion while wedging the spudge around the edge of the ear cushion.
  3. Remove the ear cushion from the headset. Remove the ear cushion from the headset.
    • Remove the ear cushion from the headset.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
The lighting is quite poor. I can't see what you're doing at all.
It's also missing a lot of information. Are they glued down? Are you able to get the ear cups off intact so they can be replaced after your wash them?
Vitrified Valkyrie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 14
Letzten 30 Tage: 51
Insgesamt: 2,927
