Zum Hauptinhalt wechseln
Astro A40 Gen2 Speaker Replacement
Was du brauchst
  1. Astro A40 Gen2 Speaker Replacement, Ear Pad: Schritt 1, Bild 1 von 2 Astro A40 Gen2 Speaker Replacement, Ear Pad: Schritt 1, Bild 2 von 2
    • Pull one corner of the pad to release it from the headset.
    • Pull the rest of the ear pad off.
  2. Astro A40 Gen2 Speaker Replacement, Speaker: Schritt 2, Bild 1 von 2 Astro A40 Gen2 Speaker Replacement, Speaker: Schritt 2, Bild 2 von 2
    • Locate the four 4.5 mm Philips #0 screws on the panel shown.
    • Remove them using a Phillips #0 head screwdriver.
    • Remove the panel.
  3. Astro A40 Gen2 Speaker Replacement: Schritt 3, Bild 1 von 2 Astro A40 Gen2 Speaker Replacement: Schritt 3, Bild 2 von 2
    • Using either your fingers or a plastic opening tool, pry off the speaker cover.
  4. Astro A40 Gen2 Speaker Replacement: Schritt 4, Bild 1 von 1
    • Locate the four 4.5 mm Philips #0 screws as shown on the speaker housing.
    • Remove the four screws using a Phillips #0 head screwdriver.
  5. Astro A40 Gen2 Speaker Replacement: Schritt 5, Bild 1 von 1
    • Remove the housing to reveal the speaker.
    • Make sure not to break the small wire holding the two portions together.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Donavan Feliz
444 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 20-18, Maness Winter 2015 Mitglied von Cal Poly, Team 20-18, Maness Winter 2015
CPSU-MANESS-W15S20G18
4 Mitglieder
10 Anleitungen geschrieben
2 Kommentare
Where do you buy the replacement speaker ? Thanks.
Steve Rosam - Antwort
what speakers can these be replaced with? this guide is a little short on details about the actual removal and replacement of the speakers. the information here is just the start
Jasper W (Spike229) - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 14
Insgesamt: 4,453
