Zum Hauptinhalt wechseln
Astro A40 TR External Headband Replacement
Was du brauchst
  1. Astro A40 TR External Headband Replacement, External Headband: Schritt 1, Bild 1 von 2 Astro A40 TR External Headband Replacement, External Headband: Schritt 1, Bild 2 von 2
    • Remove two hex screws on each side to free and remove the base plate. Do each step for both sides.
  2. Astro A40 TR External Headband Replacement: Schritt 2, Bild 1 von 2 Astro A40 TR External Headband Replacement: Schritt 2, Bild 2 von 2
    • Pull apart earpiece assembly and the connecting headband piece.
  3. Astro A40 TR External Headband Replacement: Schritt 3, Bild 1 von 2 Astro A40 TR External Headband Replacement: Schritt 3, Bild 2 von 2
    • Gently pull the padding layer off of both ends using your hands.
  4. Astro A40 TR External Headband Replacement: Schritt 4, Bild 1 von 3 Astro A40 TR External Headband Replacement: Schritt 4, Bild 2 von 3 Astro A40 TR External Headband Replacement: Schritt 4, Bild 3 von 3
    • Locate the black wiring and gently pull it out of the plastic headpiece component.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Mike
448 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 6-5, Martin Fall 2016 Mitglied von UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 Mitglieder
10 Anleitungen geschrieben
6 Kommentare
Is there any place you can purchase a new external headband? The part that holds the foam piece in place broke on mine yesterday :(
zironyy - Antwort
i dont have the screws i lost them when i dropped my headset
Sniping_Ninja10 - Antwort
Did you buy screws? I need as well but I don’t know which one is good!
photo -
Where Can I buy screws for? I know the size is T8 but how long? which one is good for? Please help me
photo - Antwort
where can i buy a new headband
Dewis Polonia - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 19
Letzte 30 Tage: 78
Insgesamt: 13,652
