Was du brauchst
Use your hand to firmly grasp the cushion and remove it from the speaker.
Repeat the process for the other side if needed.
Slide the plastic spudger beneath the dust cover of the speaker.
Lift the dust cover up with the plastic spudger.
Using your fingers, completely remove the dust cover from the speaker.
Remove four 5 mm screws from the speaker protector using a JIS #1 screwdriver.
Use your hands to remove the speaker protector.
Remove the two 2 mm long screws securing the motherboard using a Phillips #000 screwdriver.
Use your fingers to hold the wire located by the covered part and gently lift it out of its cradle.
Carefully use your fingers to disconnect the colored wires connected to the motherboard.
Use your fingers to remove the black wire from your headphones.
