Zum Hauptinhalt wechseln
Astro C40 TR Joystick Replacement
Was du brauchst
  1. Astro C40 TR Joystick Replacement, Joystick: Schritt 1, Bild 1 von 1
    • Unplug your controller from the video game console.
    • Turn the wireless mode off if it is activated on your controller.
    Frag FixBot
    Kommentar hinzufügen
  2. Astro C40 TR Joystick Replacement: Schritt 2, Bild 1 von 3 Astro C40 TR Joystick Replacement: Schritt 2, Bild 2 von 3 Astro C40 TR Joystick Replacement: Schritt 2, Bild 3 von 3
    • Use an H.20 Hexagonal screwdriver to loosen the two screws on each joystick's side.
    • Remove the face cover of the joystick by flipping the controller on its side.
    • Don't panic if the joystick falls off! It can be placed back on.
    Frag FixBot
  3. Astro C40 TR Joystick Replacement: Schritt 3, Bild 1 von 3 Astro C40 TR Joystick Replacement: Schritt 3, Bild 2 von 3 Astro C40 TR Joystick Replacement: Schritt 3, Bild 3 von 3
    • Use the 30mm TORX Screwdriver to remove the screws from the module.
    • Push on the top frame until it pops off of the module.
    • If you have a whole new joystick module, you can skip to step 6.
    Frag FixBot
  4. Astro C40 TR Joystick Replacement: Schritt 4, Bild 1 von 3 Astro C40 TR Joystick Replacement: Schritt 4, Bild 2 von 3 Astro C40 TR Joystick Replacement: Schritt 4, Bild 3 von 3
    • Connect the base frame replacement to the joystick module.
    • Insert the top frame on the module until it clicks back together.
    Frag FixBot
  5. Astro C40 TR Joystick Replacement: Schritt 5, Bild 1 von 3 Astro C40 TR Joystick Replacement: Schritt 5, Bild 2 von 3 Astro C40 TR Joystick Replacement: Schritt 5, Bild 3 von 3
    • Reassemble the joystick module and plug it back into the controller.
    • Make sure the replacement and base frame are tightly screwed together.
    • Align the module and controller as you put joystick back together.
    Frag FixBot
  6. Astro C40 TR Joystick Replacement: Schritt 6, Bild 1 von 2 Astro C40 TR Joystick Replacement: Schritt 6, Bild 2 von 2
    • Reassemble the controller by placing the face cover back on.
    • Tighten the screws on the face cover with the H.20 Hexagonal Screwdriver.
    • If it's difficult to tighten the screws, don't force it. The joystick and controller are probably not aligned correctly!
    Frag FixBot
  7. Astro C40 TR Joystick Replacement: Schritt 7, Bild 1 von 1
    • Recalibrate the controller so the new joystick can be detected by the console.
    • Connect the controller to the console and activate wire-connect mode by clicking the controller's top right corner.
    • Push the button on the back of the controller. Hold it until the controller vibrates. Release the button and repeat.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Pan
157 Reputation
1 Anleitung geschrieben
York University, Team E-21, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-21, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG21
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 30
Letzte 30 Tage: 125
Insgesamt: 5,346
