Einleitung
Use this guide when the device motherboard needs to be removed. (Soldering Required)
Was du brauchst
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
