Zum Hauptinhalt wechseln
Asus 1015E-DS03 Front Screen Trim Replacement
Was du brauchst
  1. Asus 1015E-DS03 Front Screen Trim Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Front Screen Trim Replacement: Schritt 2, Bild 1 von 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Front Screen Trim Replacement: Schritt 3, Bild 1 von 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Front Screen Trim Replacement: Schritt 4, Bild 1 von 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Front Screen Trim Replacement, Front Screen Case: Schritt 5, Bild 1 von 1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Front Screen Trim Replacement: Schritt 6, Bild 1 von 2 Asus 1015E-DS03 Front Screen Trim Replacement: Schritt 6, Bild 2 von 2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Front Screen Trim Replacement: Schritt 7, Bild 1 von 1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Becca Day
297 Reputation
2 Anleitungen geschrieben
Clemson, Team 7-4, Benson Spring 2016 Mitglied von Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 489
