Zum Hauptinhalt wechseln
Asus 1015E-DS03 Hard Drive Replacement
Was du brauchst
  1. Asus 1015E-DS03 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Hard Drive Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Hard Drive Replacement: Schritt 6, Bild 1 von 2 Asus 1015E-DS03 Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
  7. Asus 1015E-DS03 Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Hard Drive Replacement: Schritt 8, Bild 1 von 1
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Hard Drive Replacement: Schritt 9, Bild 1 von 2 Asus 1015E-DS03 Hard Drive Replacement: Schritt 9, Bild 2 von 2
    • Gently pull the strip out of the square slot.
  10. Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: Schritt 10, Bild 1 von 2 Asus 1015E-DS03 Hard Drive Replacement, Hard Drive: Schritt 10, Bild 2 von 2
    • Once the keyboard is removed, the base plate will be exposed
    • Please note that 1 screw will be covered by the warranty sticker (not shown). To complete this step it is necessary to break the warranty sticker which voids the laptop warranty.
    • Remove the 3mm screws (11) using a #0 Phillips head screwdriver
  11. Asus 1015E-DS03 Hard Drive Replacement: Schritt 11, Bild 1 von 2 Asus 1015E-DS03 Hard Drive Replacement: Schritt 11, Bild 2 von 2
    • Use the spudger to 'pop' open the track-pad base, starting from the corner shown
    • Once the corner is popped it may be easier to use your fingers to pop off the entire track-pad base
    • You will hear popping. Although this is normal, use caution pulling the track-pad base from the rest of the laptop
  12. Asus 1015E-DS03 Hard Drive Replacement: Schritt 12, Bild 1 von 2 Asus 1015E-DS03 Hard Drive Replacement: Schritt 12, Bild 2 von 2
    • You can now lift both sections of the base, exposing the hard drive.
  13. Asus 1015E-DS03 Hard Drive Replacement: Schritt 13, Bild 1 von 3 Asus 1015E-DS03 Hard Drive Replacement: Schritt 13, Bild 2 von 3 Asus 1015E-DS03 Hard Drive Replacement: Schritt 13, Bild 3 von 3
    • Release the two ZIF connectors that are labeled "IO"
    • The white bar flips away from the ribbon cable, then the ribbon cable can be gently pulled and removed from the connector
  14. Asus 1015E-DS03 Hard Drive Replacement: Schritt 14, Bild 1 von 2 Asus 1015E-DS03 Hard Drive Replacement: Schritt 14, Bild 2 von 2
    • Gently remove the hard drive from the laptop by pulling it towards the right.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
TJ Hanley
221 Reputation
1 Anleitung geschrieben
Clemson, Team 7-4, Benson Spring 2016 Mitglied von Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Mitglieder
7 Anleitungen geschrieben
1 Kommentar zur Anleitung
I pulled out the hard drive from a working 1015PE. I have all the parts and most of the screws.
I am not going to put it back together.
Can anyone use the what is left?
B&R Computer Services.
Contact info at noappleis2old4us.com
January 26, 2023
Ron Re - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 42
Insgesamt: 2,631
