Einleitung
The following guide will help the user remove the screen. The screen trim can been removed using a spudger. A Phillips #0 screwdriver is needed to remove the screws keeping the screen attached to the laptop.
Was du brauchst
Push the two tabs located below the battery in towards each other using your thumbs.
Continue to push the battery upwards until it is completely separated from the laptop as shown.
Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
When the screen case has been successfully removed, the laptop should resemble the photo shown here.
Remove the wire that is glued to the back of the screen with your fingers.
Remove the tape covering the connection port.
2 weitere Personen haben diese Anleitung absolviert.
