Zum Hauptinhalt wechseln
Asus A52F Hard Drive Replacement
Was du brauchst
  1. Asus A52F Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Asus A52F Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: Schritt 2, Bild 1 von 2 Asus A52F Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: Schritt 3, Bild 1 von 3 Asus A52F Hard Drive Replacement, Lower Case: Schritt 3, Bild 2 von 3 Asus A52F Hard Drive Replacement, Lower Case: Schritt 3, Bild 3 von 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: Schritt 4, Bild 1 von 2 Asus A52F Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: Schritt 5, Bild 1 von 3 Asus A52F Hard Drive Replacement, Hard Drive: Schritt 5, Bild 2 von 3 Asus A52F Hard Drive Replacement, Hard Drive: Schritt 5, Bild 3 von 3
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: Schritt 6, Bild 1 von 2 Asus A52F Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: Schritt 7, Bild 1 von 2 Asus A52F Hard Drive Replacement: Schritt 7, Bild 2 von 2
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Roman Justice
225 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G1
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 21
Insgesamt: 1,538
