Einleitung
This guide will teach you how to open the laptop with a screwdriver, identify and safely remove the broken WiFi card, and replace it with a working one.
Was du brauchst
Place the laptop face down with the battery facing away from you.
Locate the two buttons next to the battery.
Slide the right slider to the unlocked (red) position.
Hold the left button to the left.
Slide the battery with your other hand away from you and it should disconnect.
Remove the five Phillips # 0 screws from the back panel.
Using your finger or a plastic spudger start to carefully pry up the back planel.
First, find the Wi-Fi card
Move the protective flap back and use a Phillips size 0 screw driver to remove the two screws.
First remove both of the wires from the WiFi card.
Lift the WiFi card up and remove it.
Eine weitere Person hat diese Anleitung absolviert.
