Zum Hauptinhalt wechseln
Asus A53U-ES21 Keyboard Replacement
Was du brauchst
  1. Asus A53U-ES21 Keyboard Replacement, Battery: Schritt 1, Bild 1 von 2 Asus A53U-ES21 Keyboard Replacement, Battery: Schritt 1, Bild 2 von 2
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Asus A53U-ES21 Keyboard Replacement: Schritt 2, Bild 1 von 2 Asus A53U-ES21 Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Asus A53U-ES21 Keyboard Replacement, Keyboard: Schritt 3, Bild 1 von 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: Schritt 3, Bild 2 von 3 Asus A53U-ES21 Keyboard Replacement, Keyboard: Schritt 3, Bild 3 von 3
    • Remove the RAM cover from the bottom of the keyboard.
    • Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
    • Work the pry tool along the edge to finish removal.
    • Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
  4. Asus A53U-ES21 Keyboard Replacement: Schritt 4, Bild 1 von 3 Asus A53U-ES21 Keyboard Replacement: Schritt 4, Bild 2 von 3 Asus A53U-ES21 Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Orient the computer so the keyboard is facing toward you with the screen at the top.
    • Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
    • Use the pry tool to depress the buttons. The keyboard should pop out.
  5. Asus A53U-ES21 Keyboard Replacement: Schritt 5, Bild 1 von 3 Asus A53U-ES21 Keyboard Replacement: Schritt 5, Bild 2 von 3 Asus A53U-ES21 Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Fold the keyboard out towards you. It should still be connected by a ribbon to the rest of the computer.
    • Gently use the opening tool to lift the black piece holding the ribbon down and remove the ribbon.
    • The black piece should cover the white line on the ribbon when it is replaced.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 Mitglied von UMass Dartmouth, Team S1-G3, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G3
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 20
Insgesamt: 490
