Zum Hauptinhalt wechseln
Asus Chromebook C101P Keyboard Replacement
Was du brauchst
  1. Asus Chromebook C101P Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Keyboard Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C101P Keyboard Replacement: Schritt 4, Bild 2 von 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Keyboard Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C101P Keyboard Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C101P Keyboard Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
2 Mitglieder
5 Anleitungen geschrieben
2 Kommentare zur Anleitung
This did not work my laptop won't turn on now. Any suggestions?
Destiny Wright - Antwort Teilen
We’re sorry to hear that. We recommend you contact iFixit directly for support on this issue or to contact ASUS for further help.
Bryan Acosta - Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 23
Insgesamt: 2,101
