Zum Hauptinhalt wechseln
Asus Chromebook C101P Speakers Replacement
Was du brauchst
    1. Asus Chromebook C101P Speakers Replacement, Keyboard: Schritt 1, Bild 1 von 1
      • Flip the Chromebook so that the bottom is facing up.
      • Remove the nine T5 Torx screws.
      Frag FixBot
      Kommentar hinzufügen
    2. Asus Chromebook C101P Speakers Replacement: Schritt 2, Bild 1 von 1
      • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
      Frag FixBot
    3. Asus Chromebook C101P Speakers Replacement: Schritt 3, Bild 1 von 1
      • Remove the four black screws where the rubber grips were.
      Frag FixBot
    4. Asus Chromebook C101P Speakers Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C101P Speakers Replacement: Schritt 4, Bild 2 von 2
      • Reorient the Chromebook so the right side is facing upwards.
      • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
      Frag FixBot
    5. Asus Chromebook C101P Speakers Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C101P Speakers Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C101P Speakers Replacement: Schritt 5, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
      • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
      • Separate the keyboard from the rest of the laptop.
      Frag FixBot
    1. Asus Chromebook C101P Speakers Replacement, Speakers: Schritt 6, Bild 1 von 1
      • Remove the four Phillips #0 screws from the speakers.
      Frag FixBot
    2. Asus Chromebook C101P Speakers Replacement: Schritt 7, Bild 1 von 1
      • Remove the yellow speaker tape using tweezers.
      Frag FixBot
    3. Asus Chromebook C101P Speakers Replacement: Schritt 8, Bild 1 von 2 Asus Chromebook C101P Speakers Replacement: Schritt 8, Bild 2 von 2
      • Detach the right speaker using tweezers.
      • The right speaker has its own set of cables connecting to the motherboard. Simply tug on the cables.
      Frag FixBot
Abschluss
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
2 Mitglieder
40 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 672
