Zum Hauptinhalt wechseln
Asus Chromebook C101P Touchpad Replacement
Was du brauchst
  1. Asus Chromebook C101P Touchpad Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Flip the Chromebook so that the bottom is facing up.
    • Remove the nine T5 Torx screws.
  2. Asus Chromebook C101P Touchpad Replacement: Schritt 2, Bild 1 von 1
    • Remove the four rubber grips on the bottom side of the Chromebook using an opening tool.
  3. Asus Chromebook C101P Touchpad Replacement: Schritt 3, Bild 1 von 1
    • Remove the four black screws where the rubber grips were.
  4. Asus Chromebook C101P Touchpad Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C101P Touchpad Replacement: Schritt 4, Bild 2 von 2
    • Reorient the Chromebook so the right side is facing upwards.
    • Wedge an opening tool or spudger between the keyboard (upper case) and the lower case of the bottom portion of the Chromebook.
  5. Asus Chromebook C101P Touchpad Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C101P Touchpad Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C101P Touchpad Replacement: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the large ribbon cable.
    • Pull back the black lever on the base of the cable. While pulling back, take your tweezers and pull back on the small ribbon cable.
    • Separate the keyboard from the rest of the laptop.
  6. Asus Chromebook C101P Touchpad Replacement, Touchpad: Schritt 6, Bild 1 von 3 Asus Chromebook C101P Touchpad Replacement, Touchpad: Schritt 6, Bild 2 von 3 Asus Chromebook C101P Touchpad Replacement, Touchpad: Schritt 6, Bild 3 von 3
    • Remove the three Phillips #0 screws holding the trackpad in place.
  7. Asus Chromebook C101P Touchpad Replacement: Schritt 7, Bild 1 von 3 Asus Chromebook C101P Touchpad Replacement: Schritt 7, Bild 2 von 3 Asus Chromebook C101P Touchpad Replacement: Schritt 7, Bild 3 von 3
    • Using tweezers, pull the cable free from the touchpad.
    • Using tweezers, pry off the tape holding the touchpad down.
Abschluss
Bryan Acosta
401 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S1-G2, O'Connell Fall 2019 Mitglied von UMass Dartmouth, Team S1-G2, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G2
2 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 537
