Zum Hauptinhalt wechseln
Asus Chromebook C201 Motherboard Replacement
Was du brauchst
  1. Asus Chromebook C201 Motherboard Replacement, Palm Rest Assembly: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down with the rear end of the computer away from you.
  2. Asus Chromebook C201 Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
  3. Asus Chromebook C201 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
  4. Asus Chromebook C201 Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
  5. Asus Chromebook C201 Motherboard Replacement: Schritt 5, Bild 1 von 2 Asus Chromebook C201 Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
  6. Asus Chromebook C201 Motherboard Replacement: Schritt 6, Bild 1 von 3 Asus Chromebook C201 Motherboard Replacement: Schritt 6, Bild 2 von 3 Asus Chromebook C201 Motherboard Replacement: Schritt 6, Bild 3 von 3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
  7. Asus Chromebook C201 Motherboard Replacement: Schritt 7, Bild 1 von 2 Asus Chromebook C201 Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
  8. Asus Chromebook C201 Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the keyboard cover and safely place it somewhere face down.
  9. Asus Chromebook C201 Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to disconnect the LCD cable from the motherboard.
  10. Asus Chromebook C201 Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use the tweezers to disconnect both wifi antenna cables from the motherboard.
  11. Asus Chromebook C201 Motherboard Replacement: Schritt 11, Bild 1 von 2 Asus Chromebook C201 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Use a J0 Phillips screwdriver to remove the 6, 4mm small head silver screws.
    • Use the same J0 Phillips screwdriver to remove the 4mm large head silver screw from the head shield.
    • Remove the heat shield.
  12. Asus Chromebook C201 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Use the tweezers to disconnect the battery cable from the motherboard.
  13. Asus Chromebook C201 Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Use the tweezers to disconnect the daughterboard plug from the motherboard.
  14. Asus Chromebook C201 Motherboard Replacement: Schritt 14, Bild 1 von 2 Asus Chromebook C201 Motherboard Replacement: Schritt 14, Bild 2 von 2
    • Remove the sound cable from motherboard.
  15. Asus Chromebook C201 Motherboard Replacement: Schritt 15, Bild 1 von 1
    • Use a J0 Phillips screwdriver to remove the single, silver, 4mm screw on the motherboard.
  16. Asus Chromebook C201 Motherboard Replacement: Schritt 16, Bild 1 von 1
    • Remove the motherboard.
Abschluss
7 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-51, Cagle Spring 2016 Mitglied von USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
4 Mitglieder
10 Anleitungen geschrieben
1 Kommentar zur Anleitung
Hello
Where can we find this motherboard for the asus C201PA chromebook ?
Jean-Vincent - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 3,351
