Zum Hauptinhalt wechseln
Asus Chromebook C201 Palm Rest Assembly Replacement
Was du brauchst
  1. Asus Chromebook C201 Palm Rest Assembly Replacement, Palm Rest Assembly: Schritt 1, Bild 1 von 1
    • Flip the laptop upside down with the rear end of the computer away from you.
    Frag FixBot
    Kommentar hinzufügen
  2. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the two rear rubber feet by using one of the small, blue plastic spudgers.
    Frag FixBot
  3. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 3, Bild 1 von 1
    • Use the J0 screwdriver to remove the eight 5mm black screws on the bottom of the laptop, which includes the two that were hidden under the rear rubber feet.
    Frag FixBot
  4. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 4, Bild 1 von 1
    • Turn the laptop on its side. Use a small, blue opening tool to pry the keyboard cover and laptop apart. Begin from the top right, next to the power button, and slowly work your way around to the opposite side until the keyboard cover is detached.
    Frag FixBot
  5. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 5, Bild 1 von 2 Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 5, Bild 2 von 2
    • Gently flip the keyboard cover away from the laptop. Rest it safely upside down so the cables are not strained and are easily accessible.
    Frag FixBot
  6. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 6, Bild 1 von 3 Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 6, Bild 2 von 3 Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 6, Bild 3 von 3
    • Use the metal spudger to gently pry up the small tabs that are clamping down on the keyboard cables.
    Frag FixBot
  7. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 7, Bild 1 von 2 Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 7, Bild 2 von 2
    • Carefully pull the keyboard cables out of the connecting ports that are attached to the motherboard.
    Frag FixBot
  8. Asus Chromebook C201 Palm Rest Assembly Replacement: Schritt 8, Bild 1 von 1
    • Remove the keyboard cover and safely place it somewhere face down.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 2-51, Cagle Spring 2016 Mitglied von USF Tampa, Team 2-51, Cagle Spring 2016
USFT-CAGLE-S16S2G51
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 27
Insgesamt: 1,033
