Zum Hauptinhalt wechseln
Asus Chromebook C201PA-DS02-LG Daughterboard Replacement
Was du brauchst
  1. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 2, Bild 1 von 2 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 3, Bild 1 von 2 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 4, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 4, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 4, Bild 3 von 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
  6. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: Schritt 6, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: Schritt 6, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Metal Plate: Schritt 6, Bild 3 von 3
    • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
    • Wiggle the plate back and forth to loosen the adhesive under the plate.
    • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
    • Rotate the screwdriver in a counterclockwise direction to remove the screws.
    • Do not rest your arm or hand in the adhesive.
  7. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Daughterboard: Schritt 7, Bild 1 von 2 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement, Daughterboard: Schritt 7, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the two 4mm screws.
    • Flip up the white tab to remove the white ribbon cable.
  8. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 8, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 8, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 8, Bild 3 von 3
    • Use a plastic opening tool to flip up the connector connecting the slim blue tipped strip to the daughterboard.
    • Lift the slim blue tipped strip from the daughterboard.
  9. Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 9, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 9, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Daughterboard Replacement: Schritt 9, Bild 3 von 3
    • Place the plastic opening tools underneath the daughterboard.
    • Gently lift the daughterboard from the base of the device.
Abschluss
Brittany M Won
577 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S17-G4, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 145
