Zum Hauptinhalt wechseln
Asus Chromebook C201PA-DS02-LG Keyboard Replacement
Was du brauchst
  1. Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement, Keyboard: Schritt 1, Bild 3 von 3
    • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
    • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
  2. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 2, Bild 1 von 2 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
    • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  3. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 3, Bild 1 von 2 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Use a plastic opening tool to pry the keyboard off the edges of the computer.
    • The edges will make a popping noise.
  4. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 4, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 4, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 4, Bild 3 von 3
    • Flip up the white bar that connects the thin white strip using a plastic opening tool.
    • Grab the thin white strip and pull straight back to remove the strip from the connector.
  5. Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C201PA-DS02-LG Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
    • Grab the wide black strip and pull straight back to remove the strip from the connector.
    • Remove the keyboard by lifting it straight up.
Abschluss
Brittany M Won
577 Reputation
5 Anleitungen geschrieben
Cal Poly, Team S17-G4, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 11
Insgesamt: 203
