Zum Hauptinhalt wechseln
Asus Chromebook C202 Metal Bracket Replacement
Was du brauchst
  1. Asus Chromebook C202 Metal Bracket Replacement, Palm Rest: Schritt 1, Bild 1 von 1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202 Metal Bracket Replacement: Schritt 2, Bild 1 von 2 Asus Chromebook C202 Metal Bracket Replacement: Schritt 2, Bild 2 von 2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202 Metal Bracket Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202 Metal Bracket Replacement, Daughterboard: Schritt 4, Bild 1 von 1
    • Remove both Phillips #1 4.5 mm screws from the daughterboard.
  5. Asus Chromebook C202 Metal Bracket Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the thin band from the daughterboard. You may have to use a thin blade or spudger to lift the silver clip to release the band.
  6. Asus Chromebook C202 Metal Bracket Replacement, Metal Bracket: Schritt 6, Bild 1 von 1
    • Use a Phillips screwdriver to remove three 4 mm Phillips #1 screws from the metal bracket.
  7. Asus Chromebook C202 Metal Bracket Replacement: Schritt 7, Bild 1 von 1
    • Once all the screws are removed the metal bracket can be disconnected from the motherboard.
    • Remove the metal bracket.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 216
