Zum Hauptinhalt wechseln
Asus Chromebook C202 Motherboard Replacement
Was du brauchst
  1. Asus Chromebook C202 Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 3 Asus Chromebook C202 Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 3 Asus Chromebook C202 Motherboard Replacement, Back Panel: Schritt 1, Bild 3 von 3
    • What you need: 10 8mm screws, Tweezers, and a Phillips #1 Screwdriver
    • Remove Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Use tweezers to get two of the screws are hidden by rubber caps along the rubber rest of the device out.
  2. Asus Chromebook C202 Motherboard Replacement: Schritt 2, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    iFixit Opening Tool
    $1.99
    • What you need: plastic opening tool, Chromebook
    • Open the top portion of the Chromebook
    • To unhinge the top portion of the Chromebook, push down on the plastic opening tool.
    • Place the plastic opening tool facing upward using the upper scoop, into the edges between the front and back of the Chromebook.
    • In order to avoid damaging ribbon cables, gently lift the top portion of the Chromebook from the bottom portion.
  3. Asus Chromebook C202 Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Gently disconnect the ribbon cable connecting the trackpad and the keyboard to the motherboard.
  4. Asus Chromebook C202 Motherboard Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Remove the black and white wires from the wireless card.
  5. Asus Chromebook C202 Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the single 4 mm Phillips #1 screw pinning the wireless card in place.
  6. Asus Chromebook C202 Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Gently pull the wireless card away from the motherboard.
  7. Asus Chromebook C202 Motherboard Replacement, Battery: Schritt 7, Bild 1 von 3 Asus Chromebook C202 Motherboard Replacement, Battery: Schritt 7, Bild 2 von 3 Asus Chromebook C202 Motherboard Replacement, Battery: Schritt 7, Bild 3 von 3
    • Use a spudger or a clean fingernail to flip up the locking flap on each end of the cable—this is the unlocked position.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  8. Asus Chromebook C202 Motherboard Replacement: Schritt 8, Bild 1 von 3 Asus Chromebook C202 Motherboard Replacement: Schritt 8, Bild 2 von 3 Asus Chromebook C202 Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery.
  9. Asus Chromebook C202 Motherboard Replacement: Schritt 9, Bild 1 von 2 Asus Chromebook C202 Motherboard Replacement: Schritt 9, Bild 2 von 2
    • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket and disconnect the battery from the motherboard.
    • It may take a lot of alternating before the connector comes out. Be patient.
    • If that doesn't work, grip all the cables at once as close to the connector as possible and pull the connector slowly and steadily out of its socket.
    • Lift the battery from the bottom edge to to remove it from the Chromebook.
  10. Asus Chromebook C202 Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Unscrew one 3 mm Phillips #1 screw.
    • Unscrew one 2.5 mm Phillips #1 screw.
    • Unscrew four 4 mm Phillips #1 screws.
  11. Asus Chromebook C202 Motherboard Replacement: Schritt 11, Bild 1 von 2 Asus Chromebook C202 Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Disconnect the wires that connect the motherboard to the speakers.
    • Disconnect the motherboard from the display.
  12. Asus Chromebook C202 Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Lift the motherboard up and out of the chassis.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team 3-1, Passmore Fall 2016 Mitglied von USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 3,454
