Einleitung
The bezel is the plastic covering that surrounds the screen. It is made of strong plastic, but in the event that it does crack or need replacement, this guide will show you how to replace it.
Was du brauchst
Using a flat blade, remove the two screw covers on the front of the bezel. They are attached by adhesive, so you may have to dig at it a little bit.
Using the plastic opening tool, carefully pry off the bezel. It will come off entirely, so be careful not to break it.
