Zum Hauptinhalt wechseln
Asus Chromebook C213SA-YS02 Keyboard Replacement
Was du brauchst
    1. Asus Chromebook C213SA-YS02 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
      • Power off the device by pressing and holding the power button on the side of the device.
      • Remove the power cable from the back of the device (if applicable).
      • Do not move forward if your device is still on. This can cause harm to you and the device!
      Frag FixBot
      Kommentar hinzufügen
    2. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 2, Bild 1 von 1
      • Place the closed device on the table so that the back cover is facing up.
      • Remove the one black 4mm Phillips #00 screw on the back cover.
      • Place the iFixit opening tool in the slot and lift up the cover.
      • Slide the iFixit opening tool around the outside of the cover to remove it.
      Frag FixBot
    3. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 3, Bild 3 von 3
      In diesem Schritt verwendetes Werkzeug:
      • Remove the seven black 4mm Phillips screws underneath the back cover.
      • Remove the eight black 7mm Phillips #00 screws along the edge of the device.
      • Remove the single silver 2mm Phillips #00 screw from the top of the Wi-Fi card.
      • Carefully pull the white and black wires out of the card using tweezers.
      • Remove the Wi-Fi card.
      Frag FixBot
    4. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 4, Bild 2 von 2
      • Unhook the two ribbon cables by using the iFixit opening tool to lift the black lock mechanisms up.
      • Slide the blue ribbon out of the lock mechanism.
      • Repeat these steps for both sides of each blue ribbon.
      Frag FixBot
    5. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 5, Bild 1 von 1
      • Using your iFixit opening tool, slide the black lock mechanism toward the serial label.
      • Repeat the step on the opposite side of the cable.
      • Slide the blue cable out of the port using a pair of tweezers.
      Frag FixBot
    6. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 6, Bild 1 von 1
      • Remove the touchpad cable by lifting the black lock mechanism up by using your iFixit opening tool.
      • Gently slide the cable out of its port.
      Frag FixBot
    7. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 7, Bild 1 von 1
      • Use the iFixit opening tool to release both ends of the double male end of the speaker cable.
      • Disconnect the speaker cable from the port.
      Frag FixBot
    8. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 8, Bild 1 von 1
      • Disconnect the black LCD cable directly above the hinges of the device by using an iFixit opening tool to lift up the black lock.
      • Slide the black LCD cable out of the connection port.
      Frag FixBot
    9. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 9, Bild 1 von 1
      • Disconnect the black camera cable between the keyboard cable and the two blue ribbons which have been disconnected.
      • Using the tweezers, grab the wire end of the cable and carefully pull it away from the connection port.
      • Loosely place the disconnected cable away from the connection port.
      Frag FixBot
    10. Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 10, Bild 1 von 3 Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 10, Bild 2 von 3 Asus Chromebook C213SA-YS02 Keyboard Replacement: Schritt 10, Bild 3 von 3
      • Flip the device over and open up the LCD screen.
      • Using the iFixit opening tool, gently place the tool in between the back-plate and the keyboard and lift up.
      • Slide the tool around the outside of the keyboard and lift up the tool while moving it around the boundary of the keyboard.
      • Be careful not to jam the tool deep into keyboard. This could cause damage to the motherboard.
      • Pull the keyboard away from the back-plate. Be careful the keyboard cable is not caught on the back-plate while performing this maneuver.
      Frag FixBot
Abschluss
nathan
485 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S4-G7, Saloman Fall 2019 Mitglied von UMass Dartmouth, Team S4-G7, Saloman Fall 2019
UMASSD-SALOMAN-F19S4G7
4 Mitglieder
36 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 18
Insgesamt: 899
