Zum Hauptinhalt wechseln
Asus Chromebook C300M USB Port Replacement
Was du brauchst
  1. Asus Chromebook C300M USB Port Replacement, USB Port: Schritt 1, Bild 1 von 2 Asus Chromebook C300M USB Port Replacement, USB Port: Schritt 1, Bild 2 von 2
    • Flip the chromebook on its front.
    • Remove the screws on the back using the Phillips #1 screwdriver.
    • Remove the six 8mm screws.
    • Remove the five 5mm screws.
  2. Asus Chromebook C300M USB Port Replacement: Schritt 2, Bild 1 von 1
    • Separate the plastic case from the keyboard at the seam using a plastic opening tool.
  3. Asus Chromebook C300M USB Port Replacement: Schritt 3, Bild 1 von 2 Asus Chromebook C300M USB Port Replacement: Schritt 3, Bild 2 von 2
    • Fully separate the plastic case from the keyboard by lifting it upward.
  4. Asus Chromebook C300M USB Port Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook C300M USB Port Replacement: Schritt 4, Bild 2 von 2
    • The small and wide ribbon cables connect the keyboard to the motherboard.
    • Disconnect the small ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
    • Disconnect the wide ribbon cable by lifting the flap and sliding it out of the motherboard input toward the battery using a spudger.
  5. Asus Chromebook C300M USB Port Replacement: Schritt 5, Bild 1 von 2 Asus Chromebook C300M USB Port Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the USB port in the top right corner from the motherboard.
    • Unplug the the wide ribbon cable using spudger.
  6. Asus Chromebook C300M USB Port Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300M USB Port Replacement: Schritt 6, Bild 2 von 2
    • Remove the single 3mm screw on the left and bottom side of the USB Port using the Phillips #1 screwdriver.
    • Remove the three 5mm screws on the upper part of the USB port with the same screwdriver.
    • Lift the edge of the white casing. Remove the USB Port by pulling it toward the bottom of the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Rachel Cadle
259 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G2, Harley Spring 2019 Mitglied von IUPUI, Team S3-G2, Harley Spring 2019
IUPUI-HARLEY-S19S3G2
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 729
