Zum Hauptinhalt wechseln
Asus Chromebook C300MA DB01 Battery Replacement
Was du brauchst
  1. Asus Chromebook C300MA DB01 Battery Replacement, Removing the Back Cover: Schritt 1, Bild 1 von 1
    • Remove the eight 9.0 mm Phillips screws along the perimeter of the case.
    • Remove the three 6.0 mm Phillips screws from the center of the case.
  2. Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: Schritt 2, Bild 1 von 2 Asus Chromebook C300MA DB01 Battery Replacement, Taking off the Keyboard: Schritt 2, Bild 2 von 2
    • Slide the Jimmy in between the keyboard and underside of the laptop to remove the keyboard.
    • Leave the keyboard face down on the screen.
    • Do not pull the keyboard away from the laptop. The keyboard will still be attached with wires.
  3. Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: Schritt 3, Bild 1 von 2 Asus Chromebook C300MA DB01 Battery Replacement, Detaching keyboard: Schritt 3, Bild 2 von 2
    • Use a nylon spudger to lift the latch on each wire jack and detach the keyboard wires.
    • After the tabs have been lifted, the wire can be gently pulled out by hand.
    • Set the keyboard aside.
  4. Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: Schritt 4, Bild 1 von 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: Schritt 4, Bild 2 von 3 Asus Chromebook C300MA DB01 Battery Replacement, Removing the battery: Schritt 4, Bild 3 von 3
    • Remove the six 6.0mm Phillips screws on the battery.
    • Remove the wire jack from the battery. Use a nylon spudger to lift the latch.
    • Remove the battery from the device.
Abschluss
Earl Gill IV
193 Reputation
2 Anleitungen geschrieben
IUPUI, Team S10-G10, Wilson Spring 2019 Mitglied von IUPUI, Team S10-G10, Wilson Spring 2019
IUPUI-WILSON-S19S10G10
3 Mitglieder
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 184
