Einleitung
If your Asus Chromebook C300MA DB01 is not displaying a clear image, use this guide to replace the screen.
The screen transmits visual imagery through the wires connected to the screen. A faulty connection will transmit distorted images or no images at all.
Was du brauchst
Run the Jimmy along the edges of the screen frame to unsnap it from the connectors.
Remove the screen frame manually.
Use a Phillips #1 screwdriver to remove the four screws on each corner of the screen.
Separate the screen from the top of the Chromebook with the Jimmy.
Use the Jimmy to lift the latch on the wire jack.
Remove the wires and detach the screen from the device manually.
