Einleitung
If you are having trouble with audio output on your device this guide can be useful. Be careful when unplugging wires as to not damage them.
Was du brauchst
Remove the three 6.0 mm Philips screws from the center of the case with the #2 screwdriver bit.
Remove the eight 9.0 mm Philips screws along the perimeter of the case with the #2 screwdriver bit.
Lift the keyboard panel away from the components at its hinges, which are located at the back of the laptop.
Remove the six 6.0mm Philips screws, using the 64 bit driver from around the battery.
Unplug the wire using the plastic opening tool that connects the battery with the board.
Use plastic opening tool to pry off the wire connecting the left side speaker to the circuit board.
Eine weitere Person hat diese Anleitung absolviert.
2 Kommentare zur Anleitung
Bonjour m. Merci pour la présentation. Pourriez-vous m'indiquer l'endroit où je peux me procurer des haut-parleurs pour un hp Omen 15 ? Merci d'avance. Email : dhujardaim@hotmail.com / dhujardaim@gmail.com
