Einleitung
The motherboard is the most important part of your devise. It is responsible of everything ranging from basic processing to complex programs.
Was du brauchst
Flip the Chromebook over so that the underside is facing up.
Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
Remove the 4 "4mm" screws on the silver motherboard cover with the Phillips #000 Screwdriver.
Remove the motherboard silver mount.
Use a plastic opening tool to remove the connection from sound driver on the bottom left of the motherboard.
Use the Phillips #000 Screwdriver to remove the screw on right side of wireless card.
Remove the wireless card.
Start by lifting tape up off of the connection. Remove the connection to display.
Remove (3) three "4mm" screws that connect the hinge to the motherboard using the Phillips #000 Screwdriver.
Remove (5) five "4mm" screws around two sides of motherboard using the Phillips #000 Screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
