Zum Hauptinhalt wechseln
Asus Chromebook C300MA-DH02 Wireless Card Replacement
Was du brauchst
  1. Asus Chromebook C300MA-DH02 Wireless Card Replacement, Keyboard Panel: Schritt 1, Bild 1 von 3 Asus Chromebook C300MA-DH02 Wireless Card Replacement, Keyboard Panel: Schritt 1, Bild 2 von 3 Asus Chromebook C300MA-DH02 Wireless Card Replacement, Keyboard Panel: Schritt 1, Bild 3 von 3
    • Flip the Chromebook over so that the underside is facing up.
    • Using the Phillips PH #000 screwdriver, remove the 11 "4mm" screws on the back of the device.
  2. Asus Chromebook C300MA-DH02 Wireless Card Replacement: Schritt 2, Bild 1 von 1
    • Wedge the plastic opening tool between the bottom cover of the laptop and the keyboard panel.
    • Apply pressure and move the plastic opening tool around the border of the laptop until it pops out.
  3. Asus Chromebook C300MA-DH02 Wireless Card Replacement: Schritt 3, Bild 1 von 2 Asus Chromebook C300MA-DH02 Wireless Card Replacement: Schritt 3, Bild 2 von 2
    • Once the keyboard panel pops out, slowly move it upwards so that the keyboard connection is visible.
    • Remove the keyboard connection from the motherboard by pulling it outwards from the connector.
  4. Asus Chromebook C300MA-DH02 Wireless Card Replacement, Wireless Card: Schritt 4, Bild 1 von 1
    • Using the Phillips #000 screwdriver, unscrew the 4mm screw.
  5. Asus Chromebook C300MA-DH02 Wireless Card Replacement: Schritt 5, Bild 1 von 1
    • Gently remove the wireless card making sure to not damage the connecting port.
Abschluss
USF Tampa, Team S6-G4, Remmell Fall 2017 Mitglied von USF Tampa, Team S6-G4, Remmell Fall 2017
USFT-REMMELL-F17S6G4
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 150
