Zum Hauptinhalt wechseln
Asus Chromebook C300MA-EDU LAN Card Replacement
Was du brauchst
  1. Asus Chromebook C300MA-EDU LAN Card Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Chromebook C300MA-EDU LAN Card Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Flip the Chromebook onto its back, where there are eleven screws.
    • There are two variations of screws on the back panel:
    • Six 8.7mm screws.
    • Five 6.4mm screws.
    • Using your screwdriver with the J00 Phillips Head tip, remove the screws by turning them counter clockwise.
  2. Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 2, Bild 1 von 2 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 2, Bild 2 von 2
    • Once the screws are removed, flip the Chromebook back over.
    • Gently remove the keyboard by starting to lift up on one corner with a plastic opening tool.
    • Follow around the brim of the keyboard until it pops off.
  3. Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 3, Bild 3 von 3
    • Once you remove the keyboard, it will be connected to the CPU with two tabbed connections.
    • Release the connections from the tabs gently by flipping the white flaps up until disconnected.
    • You can now pull the ribbons out from the board and remove the keyboard.
  4. Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: Schritt 4, Bild 1 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: Schritt 4, Bild 2 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement, Battery: Schritt 4, Bild 3 von 3
    • Once the keyboard is removed, the battery is located on the bottom portion of the shell.
    • The battery is held in with six 6.5mm screws on opposing sides.
  5. Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 5, Bild 1 von 2 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 5, Bild 2 von 2
    • The battery is now held in with a tabbed connection to the CPU on the left side of the board. On the tabbed connection, there is a silver plate.
    • Gently push on the silver plate towards the screen until the plastic connection is free.
    • The tabbed connection should now slide out backwards.
  6. Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 6, Bild 2 von 2
    • At this point, using the plastic removal tool, lift the battery out of the shell.
  7. Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: Schritt 7, Bild 1 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: Schritt 7, Bild 2 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement, LAN Card: Schritt 7, Bild 3 von 3
    • Placing the Chromebook in the upright position, the LAN card is located on the upper right side of the shell.
    • The LAN card is pinned down with 2 coaxial connectors: main power and auxiliary input.
    • To disconnect, gently pull off the two connections using an upwards motion.
  8. Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 8, Bild 1 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 8, Bild 2 von 3 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 8, Bild 3 von 3
    • On the right side of the LAN card is a 3.4mm Phillips head screw.
    • Using the J0 Phillips Head Tip from your tool kit, remove the screw, turning counter clockwise until the screw is free.
  9. Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 9, Bild 1 von 2 Asus Chromebook C300MA-EDU LAN Card Replacement: Schritt 9, Bild 2 von 2
    • At this point, the LAN card is only connected to the CPU.
    • To remove, gently slide out the LAN card from the CPU’s input clip.
    • The LAN card is now disconnected.
Abschluss
USF Tampa, Team S2-G3, Nance Fall 2017 Mitglied von USF Tampa, Team S2-G3, Nance Fall 2017
USFT-NANCE-F17S2G3
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 138
