Zum Hauptinhalt wechseln
Asus Chromebook C300SA-DS02 LED Screen Replacement
Was du brauchst
  1. Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 2, Bild 3 von 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: Schritt 5, Bild 1 von 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 6, Bild 2 von 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: Schritt 8, Bild 1 von 2 Asus Chromebook C300SA-DS02 LED Screen Replacement, LED Screen: Schritt 8, Bild 2 von 2
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the antenna within the display assembly. The white cable is longer and connects to the bottom import.
  9. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 9, Bild 1 von 1
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
  10. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
  11. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 11, Bild 1 von 1
    • Gently lift the screen up and away from the laptop.
  12. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 12, Bild 1 von 1
    • Pry off the face panel on the screen using the blue prying tool.
  13. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 13, Bild 1 von 1
    • Remove the four 2mm Phillips #0 screws from the four corners of the screen.
  14. Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 14, Bild 1 von 2 Asus Chromebook C300SA-DS02 LED Screen Replacement: Schritt 14, Bild 2 von 2
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Celina Monteiro
224 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
3 Mitglieder
9 Anleitungen geschrieben
Ein Kommentar
I used this honestly I broke the screen and some of the wires in the screen are severed. Now I know for sure where the wires go and how to deconstruct it. Thank you so much!
Glorybringers Child - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 5
Insgesamt: 689
