Einleitung
This guide will walk you through the step by step process of removing the LED screen from the laptop. Screen removal is a multistep process that will require you to keep track of the parts taken out of the laptop. Each screw is accounted for in the steps they are removed.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Power the laptop off and make sure the charger is unplugged before starting.
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Unscrew the eight PH0 8.0mm screws on the laptop.
    • Unscrew the three PH0 6.0mm screws.
  2. Using the plastic opening tool, lift the back panel from the rest of the laptop.
    • Using the plastic opening tool, lift the back panel from the rest of the laptop.
    • Unhinge all four sides and corners
    • Slowly separate the keyboard panel from the back panel.
    • You won't be able to completely remove the two panels. They are connected by a ribbon cable. Carefully disconnect the cable from the green motherboard.
    • The wide ribbon cable connects the keyboard to the motherboard.
    • Disconnect the wide ribbon cable by sliding it out of the motherboard input. Pull the cable toward the battery to dislodge.
    • The narrow ribbon cable connect the track pad to the motherboard.
    • Just like the previous step, disconnect the narrow ribbon cable by sliding it out of the motherboard input. Pull the cable toward the battery to dislodge.
    • Remove the keyboard from the laptop.
    • Remove the six 6.0mm PH0 screws around the battery.
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
    • Lift the battery out of the laptop.
    • Unplug the black and white cable from the motherboard.
    • These two wires connect to the webcam at the top of your monitor. The white cable is longer and connects to the bottom import.
    • Peel back the tape covering the plug.
    • Slide the cable towards the screen and out of the input.
    • Unscrew the 6 screws (5 millimeter) on the top right and left.
    • Gently lift the screen up and away from the laptop.
    • Pry off the face panel on the screen using the blue prying tool.
    • Remove the four 2mm PH0 screws from the four corners of the screen.
    • Gently lift screen
    • Peel back the adhesive covering the cable.
    • Remove the cable to free the screen.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Celina Monteiro
Mitglied seit 17.10.2017
113 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
3 Mitglieder
4 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 266
