Einleitung
This repair guide demonstrates the step by step process of removing the VECO speakers from the laptop. They are located inside the laptop and under the battery which will require the removal of both the keyboard and the battery before gaining access.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
Remove the three 6.0mm Phillips #0 screws.
Open the laptop.
Using an iFixit opening tool, pry along the edges of the keyboard.
Lift the keyboard and slide it gently towards you.
Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
Start by removing the right speaker first.
There are two metal clips and one plastic clip holding the right speaker in place. Push them back and lift speaker out of the laptop.
Untangle the wire connecting the right speaker to the left speaker.
Move right speaker and wires away from your working space.
Ein weiterer Nutzer hat diese Anleitung absolviert.
