Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This repair guide demonstrates the step by step process of removing the VECO speakers from the laptop. They are located inside the laptop and under the battery which will require the removal of both the keyboard and the battery before gaining access.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Power the laptop off and make sure the charger is unplugged before starting. Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Open the laptop. Using an iFixit opening tool, pry along the edges of the keyboard. Lift the keyboard and slide it gently towards you.
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable. Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable. Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Remove the keyboard from the laptop.
    • Remove the keyboard from the laptop.
  5. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  6. Remove the six 5.6mm Phillips #0 screws around the battery. Remove the six 5.6mm Phillips #0 screws around the battery.
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  7. Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard. Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  8. Lift the battery out of the laptop.
    • Lift the battery out of the laptop.
  9. Unplug the speaker cable from the motherboard.
    • Unplug the speaker cable from the motherboard.
  10. Start by removing the right speaker first. There are two metal clips and one plastic clip holding the right speaker in place.  Push them back and lift speaker out of the laptop.
    • Start by removing the right speaker first.
    • There are two metal clips and one plastic clip holding the right speaker in place. Push them back and lift speaker out of the laptop.
    • Use a screwdriver to gently push back the metal clips.
  11. Untangle the wire connecting the right speaker to the left speaker. Move right speaker and wires away from your working space.
    • Untangle the wire connecting the right speaker to the left speaker.
    • Move right speaker and wires away from your working space.
    • Do not lift wire straight up, there are five interlocking ribs holding this wire in place.
  12. There are two metal clips and one plastic clip holding the right speaker in place.  Push them back and lift speaker out of the laptop.
    • You can use a screwdriver to push back the clips if needed.
  13. Lift speakers and cable away from the laptop.
    • Lift speakers and cable away from the laptop.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sam LaBelle
107 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S1-G7, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G7, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G7
3 Mitglieder
9 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 1
Insgesamt: 214
