Zum Hauptinhalt wechseln
Einleitung
If your Asus Chromebook C300SA-DS02 WiFi card has been damaged, use this guide to replace it. Prior to replacing the wireless card, you will need to remove the back cover and keyboard and disconnect the battery for safety.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Power the laptop off and make sure the charger is unplugged before starting.
    • Remove the eight 8.0mm Phillips #0 screws on the bottom of the laptop.
    • Remove the three 6.0mm Phillips #0 screws.
  2. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 2, Bild 3 von 3
    • Open the laptop.
    • Using an iFixit opening tool, pry along the edges of the keyboard.
    • Lift the keyboard and slide it gently towards you.
    • Do not completely remove the keyboard. It is still connected to the back panel by a pair of ribbon cables.
  3. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 3, Bild 3 von 3
    • Disconnect the two ZIF connectors by prying up the locking bar with a spudger and removing the ribbon cable.
  4. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard from the laptop.
  5. Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: Schritt 5, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement, Battery: Schritt 5, Bild 2 von 2
    • Remove the six 5.6mm Phillips #0 screws around the battery.
  6. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 6, Bild 2 von 2
    • Using your thumb and index finger, pinch the multi-color cable and disconnect it from the motherboard.
  7. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 7, Bild 1 von 1
    • Lift the battery out of the laptop.
  8. Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: Schritt 8, Bild 1 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: Schritt 8, Bild 2 von 3 Asus Chromebook C300SA-DS02 WiFi Card Replacement, WiFi Card: Schritt 8, Bild 3 von 3
    • Use the spudger to pop the black and white coaxial WiFi cables up from the WiFi card.
  9. Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 9, Bild 1 von 2 Asus Chromebook C300SA-DS02 WiFi Card Replacement: Schritt 9, Bild 2 von 2
    • Remove the one 3.6mm Phillips #0 screw from the WiFi card.
    • Pull and lift the WiFi card away from the motherboard.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Sarah Westberg
15.078 Reputation
65 Anleitungen geschrieben
iFixit Mitglied von iFixit
Community
148 Mitglieder
15.483 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 7
Insgesamt: 275
