Zum Hauptinhalt wechseln
Asus Chromebook C523N Keyboard Replacement
Was du brauchst
  1. Asus Chromebook C523N Keyboard Replacement, Back Cover: Schritt 1, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
    Frag FixBot
  2. Asus Chromebook C523N Keyboard Replacement: Schritt 2, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
    Frag FixBot
  3. Asus Chromebook C523N Keyboard Replacement: Schritt 3, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 3, Bild 2 von 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
    Frag FixBot
  4. Asus Chromebook C523N Keyboard Replacement, Speaker: Schritt 4, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement, Speaker: Schritt 4, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement, Speaker: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
    Frag FixBot
  5. Asus Chromebook C523N Keyboard Replacement: Schritt 5, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 5, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 5, Bild 3 von 3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
    Frag FixBot
  6. Asus Chromebook C523N Keyboard Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
    Frag FixBot
  7. Asus Chromebook C523N Keyboard Replacement: Schritt 7, Bild 1 von 1
    • Gently grab both speakers and lift them from the Chromebook to remove.
    Frag FixBot
  8. Asus Chromebook C523N Keyboard Replacement, Battery: Schritt 8, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement, Battery: Schritt 8, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement, Battery: Schritt 8, Bild 3 von 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
    Frag FixBot
  9. Asus Chromebook C523N Keyboard Replacement: Schritt 9, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 9, Bild 2 von 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
    Frag FixBot
  10. Asus Chromebook C523N Keyboard Replacement: Schritt 10, Bild 1 von 1
    • Remove the battery from the laptop.
    Frag FixBot
  11. Asus Chromebook C523N Keyboard Replacement, Motherboard: Schritt 11, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement, Motherboard: Schritt 11, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement, Motherboard: Schritt 11, Bild 3 von 3
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
    Frag FixBot
  12. Asus Chromebook C523N Keyboard Replacement: Schritt 12, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 12, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 12, Bild 3 von 3
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
    Frag FixBot
  13. Asus Chromebook C523N Keyboard Replacement: Schritt 13, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 13, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 13, Bild 3 von 3
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
    Frag FixBot
  14. Asus Chromebook C523N Keyboard Replacement: Schritt 14, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 14, Bild 2 von 2
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
    Frag FixBot
  15. Asus Chromebook C523N Keyboard Replacement: Schritt 15, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 15, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 15, Bild 3 von 3
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
    Frag FixBot
  16. Asus Chromebook C523N Keyboard Replacement: Schritt 16, Bild 1 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 16, Bild 2 von 3 Asus Chromebook C523N Keyboard Replacement: Schritt 16, Bild 3 von 3
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
    Frag FixBot
  17. Asus Chromebook C523N Keyboard Replacement: Schritt 17, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 17, Bild 2 von 2
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
    Frag FixBot
  18. Asus Chromebook C523N Keyboard Replacement: Schritt 18, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 18, Bild 2 von 2
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
    Frag FixBot
  19. Asus Chromebook C523N Keyboard Replacement: Schritt 19, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 19, Bild 2 von 2
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
    Frag FixBot
  20. Asus Chromebook C523N Keyboard Replacement, Touchpad: Schritt 20, Bild 1 von 1
    • Pull gently on the touchpad cable connector to disconnect.
    Frag FixBot
  21. Asus Chromebook C523N Keyboard Replacement: Schritt 21, Bild 1 von 1
    • Carefully, remove the tape from the touch pad only.
    Frag FixBot
  22. Asus Chromebook C523N Keyboard Replacement: Schritt 22, Bild 1 von 1
    • Remove the three 1.4 mm JIS #00 screws.
    Frag FixBot
  23. Asus Chromebook C523N Keyboard Replacement: Schritt 23, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement: Schritt 23, Bild 2 von 2
    • Lift at the far edge of the touchpad to remove it.
    Frag FixBot
  24. Asus Chromebook C523N Keyboard Replacement, Keyboard: Schritt 24, Bild 1 von 2 Asus Chromebook C523N Keyboard Replacement, Keyboard: Schritt 24, Bild 2 von 2
    • Disconnect the two ribbon cables from the daughterboard.
    Frag FixBot
  25. Asus Chromebook C523N Keyboard Replacement: Schritt 25, Bild 1 von 1
    • Remove the four 0.4mm JIS #00 screws from the daughterboard.
    • Remove the daughterboard.
    Frag FixBot
  26. Asus Chromebook C523N Keyboard Replacement: Schritt 26, Bild 1 von 1
    • Remove the two 0.4mm JIS #00 screws on the left hinge.
    Frag FixBot
  27. Asus Chromebook C523N Keyboard Replacement: Schritt 27, Bild 1 von 1
    • Lift the keyboard of the Chromebook off of the screen.
    Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Great walk through. I used this to replace a keyboard on a C423N ASUS. Everything but the track pad connector on the mother board and three screws instead of 2 on the screen hinges is the same.
Charles Stanley - Antwort Teilen
Hi there
How would I replace the screen for this model??
Saif - Antwort Teilen
how to replace ssd in motherbord
Suresh dhakar - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 53
Insgesamt: 2,826
