Zum Hauptinhalt wechseln
Asus Chromebook Flip C100 Lower Case Replacement
Was du brauchst
  1. Asus Chromebook Flip C100 Lower Case Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
    • Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
  2. Asus Chromebook Flip C100 Lower Case Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to remove the four bottom rubber feet.
  3. Asus Chromebook Flip C100 Lower Case Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the four screws under the feet using a screwdriver with a J100 tip.
  4. Asus Chromebook Flip C100 Lower Case Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to pry up the palm rest assembly.
  5. Asus Chromebook Flip C100 Lower Case Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the two cables from the motherboard with tweezers
Abschluss
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Jesse Ye
527 Reputation
1 Anleitung geschrieben
Ein Kommentar
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
Matthew Sylvester - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 6
Letzte 30 Tage: 9
Insgesamt: 5,110
