Einleitung
This prerequisite is required in order to replace or fix some components inside the bottom of the computer.
Was du brauchst
Unscrew the eight bottom cover screws (one of them is under the hand) using a screwdriver with a J1000 tip.
Unscrew the middle screw towards the top of the device using a screwdriver with a T5 tip.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect the two cables from the motherboard with tweezers
11 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
great guide, though i found the nine screws on the outside required a t5 tip, while the 5 under the feet looked like they were either j100 or j1000, but a philips head worked.
