Zum Hauptinhalt wechseln
Asus Chromebook Flip C302CA Battery Replacement
Was du brauchst
  1. Asus Chromebook Flip C302CA Battery Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Turn the laptop over so the bottom is facing you.
  2. Asus Chromebook Flip C302CA Battery Replacement: Schritt 2, Bild 1 von 3 Asus Chromebook Flip C302CA Battery Replacement: Schritt 2, Bild 2 von 3 Asus Chromebook Flip C302CA Battery Replacement: Schritt 2, Bild 3 von 3
    • Remove two rubber caps on the top.
    • Remove the two 1 mm screws using the Phillips #00 screwdriver.
  3. Asus Chromebook Flip C302CA Battery Replacement: Schritt 3, Bild 1 von 3 Asus Chromebook Flip C302CA Battery Replacement: Schritt 3, Bild 2 von 3 Asus Chromebook Flip C302CA Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the ten 2 mm screws from the back panel using a T5 Torx screwdriver.
    • Carefully remove the back panel using an opening pick.
  4. Asus Chromebook Flip C302CA Battery Replacement: Schritt 4, Bild 1 von 2 Asus Chromebook Flip C302CA Battery Replacement: Schritt 4, Bild 2 von 2
    • Remove the back panel from the laptop.
  5. Asus Chromebook Flip C302CA Battery Replacement, Battery: Schritt 5, Bild 1 von 3 Asus Chromebook Flip C302CA Battery Replacement, Battery: Schritt 5, Bild 2 von 3 Asus Chromebook Flip C302CA Battery Replacement, Battery: Schritt 5, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Remove the sticker holding the cable using a pair of tweezers.
    • Detach the cable from the motherboard by lifting it up with a spudger.
    • Always use a plastic or nylon ESD-safe tool. Metal spudger and other sharp tools can puncture a battery, potentially causing a fire.
  6. Asus Chromebook Flip C302CA Battery Replacement: Schritt 6, Bild 1 von 2 Asus Chromebook Flip C302CA Battery Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 2 mm screws holding the battery using a Phillips #00 screwdriver.
  7. Asus Chromebook Flip C302CA Battery Replacement: Schritt 7, Bild 1 von 1
    • Carefully lift up the battery from the front side to remove it from the laptop.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
Gateway, Team 1-2, Saknee Spring 2022 Mitglied von Gateway, Team 1-2, Saknee Spring 2022
GCC-SAKNEE-S22S1G2
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
If anyone has issues with the Chromebook not recognizing the new battery, I saw this posted "Note: If the new battery is not recognized during the initial installation, please reinstall and check if the interface is fully connected. Discharge the new battery to 10-20% (not 0%), then charge and cycle 3-4 times to wake up the new battery. Also, disconnect the old battery and hold down the power button for 20 seconds, then connect the new battery. This drains the residual or flea power and once the laptop is reassembled the battery should function properly."
Kirk Winterrowd - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 23
Insgesamt: 1,013
