Einleitung
After so many charging cycles, the battery in your Chromebook will begin to lose power and won't hold a charge. Buying a new computer is more expensive than replacing a broken battery. Use this guide to replace a broken Asus C436F Chromebook battery.
Remember to turn off the Chromebook before proceeding with the replacement. Let the Chromebook discharge before proceeding. If not, you might burn your motherboard.
Was du brauchst
Flip your Chromebook over so the bottom case is facing up.
Use a Torx T5 screwdriver to remove eleven 3 mm screws from the bottom of your device.
Insert the end of an opening tool into the seam between the bottom and top case to release the clips holding them together.
Remove the back panel of your Chromebook.
Use a Phillips #0 screwdriver to remove the four M2 x 3 mm screws holding the battery to the chassis.
Slide the metal lock that connects the battery to the motherboard backward (to the right). Then, lift the white connector straight out of the socket on the motherboard.
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
