Zum Hauptinhalt wechseln
Asus EEE PC 1000HD Keyboard Replacement
Was du brauchst
  1. Asus EEE PC 1000HD Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Note: Prior to changing the keyboard on your laptop, be sure to have a replacement keyboard on hand.
  2. Asus EEE PC 1000HD Keyboard Replacement: Schritt 2, Bild 1 von 2 Asus EEE PC 1000HD Keyboard Replacement: Schritt 2, Bild 2 von 2
    • Use a metal spudger and carefully insert the end of the flat tip into the edge of the keyboard.
    • Hold one end of the keyboard down to make prying easier.
    • Gently lift the metal spudger until you begin hearing clicking noises; these are the sounds of the keyboard unclasping from the board below.
  3. Asus EEE PC 1000HD Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Once you lift the keyboard, there will be a metal tab that connects the keyboard to the metal panel below.
    • Detach this metal tab slowly.
  4. Asus EEE PC 1000HD Keyboard Replacement: Schritt 4, Bild 1 von 1
    • The keyboard should be fully detached.
    • With your new replacement keyboard, insert the metal tab back into the metal panel. Press gently on the keyboard to lock it into place.
    • There should be a few clicking noises as the new keyboard latches onto the metal board.
Abschluss
Emily Gao
107 Reputation
1 Anleitung geschrieben
UC Santa Barbara, Team S2-G6, Weedon Fall 2017 Mitglied von UC Santa Barbara, Team S2-G6, Weedon Fall 2017
UCSB-WEEDON-F17S2G6
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 41
Insgesamt: 984
