Einleitung
In this guide we will provide you with the necessary information to replace the screen on an Asus Eee PC 1000HA.
Was du brauchst
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Use a #00 Phillips Head screw driver to remove the 4.8mm screws.
There will be 6 screws total.
Use the #00 Phillips Head screw driver to remove the 5.44mm screws.
There are 6 screws total.
Gently pull the tab that is connecting the laptop to the screen, to fully disconnect the screen from the laptop.
Eine weitere Person hat diese Anleitung absolviert.
