Einleitung
Follow this guide to replace your battery. This guide is also useful for temporarily removing your battery in order to safely work on other sections of your netbook.
Lay the laptop down with the bottom facing upwards.
Locate the two battery lock slide tabs.
Slide the tabs outward to unlock the battery.
While holding the left tab outward, slide the battery away from you to remove it.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
