Zum Hauptinhalt wechseln
Asus Eee PC 1000HE Hard Drive Replacement
Was du brauchst
    1. Asus Eee PC 1000HE Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 1
      • Lay the laptop down with the bottom facing upwards.
      • Locate the two battery lock slide tabs.
      Frag FixBot
      Kommentar hinzufügen
    2. Asus Eee PC 1000HE Hard Drive Replacement: Schritt 2, Bild 1 von 2 Asus Eee PC 1000HE Hard Drive Replacement: Schritt 2, Bild 2 von 2
      • Slide the tabs outward to unlock the battery.
      • The right tab will remain in the unlocked position while the left tab must be held.
      • While holding the left tab outward, slide the battery away from you to remove it.
      Frag FixBot
    1. Asus Eee PC 1000HE Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 2 Asus Eee PC 1000HE Hard Drive Replacement, Hard Drive: Schritt 3, Bild 2 von 2
      • Using the Ph00 (+) Phillips screw head, unscrew the two 4 mm screws that hold the back panel in place.
      • Use the spudger to gently pry off the back panel.
      Frag FixBot
    2. Asus Eee PC 1000HE Hard Drive Replacement: Schritt 4, Bild 1 von 2 Asus Eee PC 1000HE Hard Drive Replacement: Schritt 4, Bild 2 von 2
      • Use the PH00 (+) screw head and screw driver to remove the 4 mm screw holding down the hard drive cover.
      • The hard drive cover is the silver plate on top of the hard drive.
      Frag FixBot
    3. Asus Eee PC 1000HE Hard Drive Replacement: Schritt 5, Bild 1 von 2 Asus Eee PC 1000HE Hard Drive Replacement: Schritt 5, Bild 2 von 2
      • Slide the hard drive from the left towards the right side to detach it
      • Once the hard drive is detached, lift the black tab and remove from the netbook.
      • Do not continue with the next 3 steps if you are not attempting to replace your hard drive. Proceed to the next section instead.
      Frag FixBot
    4. Asus Eee PC 1000HE Hard Drive Replacement: Schritt 6, Bild 1 von 2 Asus Eee PC 1000HE Hard Drive Replacement: Schritt 6, Bild 2 von 2
      • Do not continue with this step or the next two steps if replacing the hard drive is not the goal. For all other guides, simply removing the hard drive from the PC (shown in previous steps) is the only necessary step.
      • To remove the metal hard drive casing, use a T6 (star head) screwdriver head to remove six 4mm screws marked by the red circles in the picture.
      Frag FixBot
    5. Asus Eee PC 1000HE Hard Drive Replacement: Schritt 7, Bild 1 von 3 Asus Eee PC 1000HE Hard Drive Replacement: Schritt 7, Bild 2 von 3 Asus Eee PC 1000HE Hard Drive Replacement: Schritt 7, Bild 3 von 3
      • Next, remove the two 4mm screws on each side of the hard drive case shown by the blue circles. Use the PH00 (+) Philips head and screwdriver head used in the previous step to remove these 4 mm screws.
      • There should be 4 total screws, 2 on each side.
      Frag FixBot
    6. Asus Eee PC 1000HE Hard Drive Replacement: Schritt 8, Bild 1 von 1
      • Remove the hard drive from the metal casing by lifting it up.
      Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Clemson, Team 6-2, Benson Spring 2016 Mitglied von Clemson, Team 6-2, Benson Spring 2016
CLEM-BENSON-S16S6G2
4 Mitglieder
91 Anleitungen geschrieben
1 Kommentar zur Anleitung
This guide used to have 8 steps as of 2017-06-19. I have edited out step 6 because it is unnecessary and risks damaging the hard drive. The screws on top of the hard drive should never be taken out outside of specialist situations such as data recovery. Removing the screws along the sides is all that is needed to remove the drive from the metal casing. Do not follow step 6 if there are still 8 steps displayed!
azureskies - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 32
Insgesamt: 3,087
