Einleitung
Follow this guide to replace the keyboard of your netbook. Removing the keyboard is also necessary to access many of the interior components of your device.
Was du brauchst
Lay the laptop down with the bottom facing upwards.
Locate the two battery lock slide tabs.
Slide the tabs outward to unlock the battery.
While holding the left tab outward, slide the battery away from you to remove it.
Identify the four connection points holding the top of the keyboard to the main body of the netbook. To remove the keyboard, use the spudger to unhook the keyboard upwards at these points.
Flip the keyboard over by pulling the top edge of the keyboard away from the netbook body, using the bottom edge as a hinge point.
Locate the opaque strip, or ribbon cable, connecting the back of the keyboard to the hardware of the netbook.
To disconnect the ribbon cable, use a plastic opening tool to pull each side of the black plastic strip, located below the ribbon cable, away from the ribbon cable.
The black strip will disconnect completely from the ribbon cable. The keyboard will then be detached from the netbook's body and can be safely removed.
2 weitere Personen haben diese Anleitung absolviert.
