Einleitung
If you are having problems with the RAM on your device, this guide will help you replace it.
Was du brauchst
Lay the laptop down with the bottom facing upwards.
Locate the two battery lock slide tabs.
Slide the tabs outward to unlock the battery.
While holding the left tab outward, slide the battery away from you to remove it.
Use a PH00 (+) phillips head to unscrew the two 7 mm screws holding down the back panel.
Use the spudger to pry off the back cover.
Push the metal bars on the sides of the RAM card to pull them out away from each other
Lift the RAM card out
2 weitere Nutzer:innen haben diese Anleitung absolviert.
