Zum Hauptinhalt wechseln
Asus Eee PC 1005PEB Battery Replacement
  1. Asus Eee PC 1005PEB Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Start by placing the laptop upside-down on a flat surface.
    • Find the two clips on the back portion of the laptop.
  2. Asus Eee PC 1005PEB Battery Replacement: Schritt 2, Bild 1 von 1
    • Using your finger, push the clip labeled with a "1" on the laptop from the lock position to unlock position.
    • This clip will hold itself, so after you move it to the unlock position you can remove your finger.
  3. Asus Eee PC 1005PEB Battery Replacement: Schritt 3, Bild 1 von 2 Asus Eee PC 1005PEB Battery Replacement: Schritt 3, Bild 2 von 2
    • Using your finger, push and hold the pin indicated by a "2" on the laptop from the lock to unlock position.
    • While holding this pin in the unlock position, use your other hand to pull the battery horizontally away from the laptop.
    • When the pins on the battery that reach towards the laptop are away from the laptop, you can release the "2" clip.
  4. Asus Eee PC 1005PEB Battery Replacement: Schritt 4, Bild 1 von 1
    • Using both hands, pull the battery horizontally away from the laptop.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Aaron Arenas
751 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 13-32, Maness Spring 2014 Mitglied von Cal Poly, Team 13-32, Maness Spring 2014
CPSU-MANESS-S14S13G32
5 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 1,566
