Zum Hauptinhalt wechseln
Asus Eee PC 1201HAB Hard Drive Replacement
Was du brauchst
  1. Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: Schritt 1, Bild 1 von 2 Asus Eee PC 1201HAB Hard Drive Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Use a plastic opening tool and carefully pry the top panel from the base.
  2. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 2, Bild 1 von 3 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 2, Bild 2 von 3 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Slowly lift the keyboard from the base.
    • Disconnect the attached ribbon from under the keyboard.
  3. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the keyboard.
  4. Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 Asus Eee PC 1201HAB Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Lay the laptop with the back facing up.
    • With a Phillips #0 screwdriver, remove the eight 6mm screws on the back of the laptop.
  5. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 5, Bild 1 von 3 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 5, Bild 2 von 3 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 5, Bild 3 von 3
    • Slide the tabs outward to remove the battery.
  6. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 6, Bild 1 von 2 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 6, Bild 2 von 2
    • Flip the device so that you are facing the screen.
    • Remove the ten 4mm screws on the silver panel under the keyboard using a Phillips #0 screwdriver.
  7. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 7, Bild 1 von 3 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 7, Bild 2 von 3 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 7, Bild 3 von 3
    • Using a plastic opening tool, remove the top panel of the laptop.
  8. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 8, Bild 1 von 2 Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 8, Bild 2 von 2
    • Using a Phillips #0 screwdriver, remove the four 4mm screws connecting the hard drive.
  9. Asus Eee PC 1201HAB Hard Drive Replacement: Schritt 9, Bild 1 von 1
    • Remove and replace the hard drive.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Katherine Chan
353 Reputation
2 Anleitungen geschrieben
UC Davis, Team S7-G3, Lore Fall 2018 Mitglied von UC Davis, Team S7-G3, Lore Fall 2018
UCD-LORE-F18S7G3
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 36
Insgesamt: 799
